MX5100 DT 3-pt lowering control
SRRGC1
BX1870-1, BX23S TLB, RTV XG850, MX5100DT
Jan 6, 2021
208
75
Bloomsburg
Issue with the 3-pt needle valve control which regulates the speed in which the 3-pt lowers. Was not allowing 3-pt to lower with ballast attached. Had to turn the control nearly all the way out to get 3-pt to go down. I do turn this control knob in/out occasionally to make sure it does not become stuck. Working OK now. Anyone others having the same issue with this control?
freewheel3
MX5000DT LA852, BX1800D, B6000DT, B6200HSTD, B7100HSTD, L185, T1700HX, ZD1211
Mar 9, 2013
334
Alberta
No, but you might have had a small piece of debris stuck in the needle valve, causing a temporary blockage.
