my new BX25D & hard cab are on its way to replace my BX24.
I have a couple quick questions, to see what products will work, if they exist.
I apologize that there may be answers to all this by searching around but I'm hopeful to consolidate some answers to what may be commonly asked questions. Thanks for the input
Shield Plate:
I'd like to get a shield plate that will protect the HST fan yet don't want to have to remove when servicing fuel filter, or when using the Mid Mount Mower. Which plate from Bro-Tek or BX Panded accomplishes this? I understand there is a front shield as well, is this the one that cannot be used whilst MMM is attached? If so, I'll avoid it as I don't want to have a shield that cannot be used with the Mower. Are the skid plates even required with the new BX25D to protect the HST fan - did Kubota catch on that something was needed here and build it into the new units?
Tow Hitch:
I often find myself wanting to tow with a 2" ball while the backhoe is attached. I've seen some welded U bolt type setups but I prefer to use the ball mount hitch. Has anyone come up with a ball hitch that can quick connect to the bucket of the backhoe? Something that won't interfere with digging, or can be quickly removed when digging?
Fuel Shutoff:
Has anyone had longterm success installing a fuel shutoff valve in-line with the undermount fuel filter? This is always a messy operation even with vice grips and always needs to be done at the worst time. Do fuel shutoff valves have the durability to hold-up? If so, what size will fit the diameter of the fuel line and on what side of the fuel line should it go (rear or front fuel line; i.e., the bow or stern)
Quick Connect:
I understand the BX25D has some quick connects for the FEL bucket, making it easier to go from FEL Bucket, to Forks for example. I have a Rear PTO B2789 Snowblower with a 3pt. hitch connect. Pg. 15 of the Manual, Figure 9 illustrates a Quick Hitch. Is there some sort of quick connect related to the 3 point hitch that I'm missing?
Shield Plate:
Tow Hitch:
Fuel Shutoff:
Quick Connect:
