Mowing with a Bx
dlsmith
BX2230, LA211
Nov 15, 2018
1,362
1,063
Goshen, IN
I've got a BX2230 with the 60" MMM, and mow 3 acres with over 30 trees I mow around. Takes me 1.5 to 2 hours depending on how many limbs I have to stop and trim so they don't hit me.
Great machine for mowing, only takes about 1.25 to 1.5 gallons to do the yard.
ehenry
BX22, FEL, BH, 40" pto tiller, 42" Bushog Squealer, pto hole digger, B7300 w/60"
Mar 25, 2014
363
92
Canton, MS
FreeHeeler is 110% in his post about the Ferris machine. A Ferris will be my next ZTR. I've had a 54" Deere z910a for 15 years but it rides rough as a log wagon! I mow slopes and ditch banks with it and it will out mow my BX22 and b7300. Like the others have said, if you can swing it get a ztr as well.
greif
BX2230 tractor, RCK54-22BX mower
Jun 20, 2021
Pittsford, New York
When I got my BX2230 with 54 inch deck, I thought I would have to mow a lot with my push mower in hard to reach spots. Turns out I almost never have to.
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
237
253
Pennsylvania
I use my JD 455 AWS diesel for mowing, turns as tight as a ZT
plus I can use it for other tasks as well.
I don't use the BX for mowing only as a loader.
WhatnxtBX
BX2380
Jun 10, 2019
35
11
Lk Stevens, WA
I moved from a quarter acre to 15 acres last October. I'm thinking about a riding mower. But a used bx with just the deck can be had for about 1500 more than a gr with similar hp. I have a lot of trees to mow around. Will the bx be clumsy as compared to the gr?
I mow 6 acres, 2.5 around the house and the rest is field with trees and other stationary obstacles with a by BX 2380 and 60" MMM. The BX does great. I have a ditch to mow that is a 45deg slope that the BX can not do. Added a pull behind 60" finishing mower that I can offset that works on the slope and gets under the low branches of the trees. Mowing time was effectively cut in half with a combined 120" wide cut. If you can not go faster, go wider.
PA452
B2650
55
Western PA
I used to have a BX23. I liked mowing with it a lot.
I've always heard ZTs are not good for steep slopes. Even had a dealer say that.
GrumpyFarmer
5,208
For what’s it’s worth, a previous neighbor (not sure the neighbor was a benchmark or anything 😉) rolled a ZT over on himself on a hill side that my BX and B both mowed just fine. He was lucky to have only broken an arm. Even afterwards still used a ZT and it was normal to see it wheelie…again most certainly not a benchmark.
