Moving 3rd Function Buttons on Joystick?
5,014
That is a very expensive button switch if you have to replace it from Kubota. Lucky for us, someone much wiser than I found the OEM switch for just under $11.00. https://www.mouser.com/ProductDetai...nLek5ZkN3rCjnpiPHKr2mdQcsw0sszJRoCEMsQAvD_BwE
Chanceywd
Kubota L2501DT BH77 VIRNIG URG60-CT 1950 8N
Mar 26, 2021
636
514
central ny
Find the power wire, and install a switch to turn it off when you don't need it. Problem solved.
That is what I did with my summit valve. I drilled a hole and installed it in the loader valve plastic. It was a small 30 amp rocker from advance auto and has a led so i know at a glance if it is on.
Bill
mikester
M59 TLB
Oct 21, 2017
3,666
2,168
www.divergentstuff.ca
Out of curiosity do you have a 3rd function lockout button on your machine? My M59 has one. The buttons are also on the side for thumb operation and are protected with bump guards.
If you don't have a lockout button you might want to consider adding one, probably all you need is a SPST switch on the 12V feed.
