Microwave oven
bucktail
Jun 13, 2016
1,293
217
MN
My microwave quit working. Went blank when the cooking cycle was done. I put a new fuse in it. After 1 2 minute cycle and 1 1 minute cycle the new fuse blew. Is there anything I should try before I scrap the microwave?
4,133
Sidekick
Jul 29, 2023
1,236
1,777
N.Y,
You can check the voltage in your outlet. Sometimes in hot weather with peak demands voltage drops causing higher amp draw on appliances.
John T
2017 BX23S
May 5, 2017
1,269
803
under a rock
I'd check the capacitor. Thats a cheap fix.
if it's the Magnatron, it's probably best to scrap it.
little niggling things can blow a fuse also... like a short in the wiring/door switch or the board.
if you scrap it, save the transformer.... you can use it to make a nifty wood burner...
4,133
If you scrap it…. DIS assemble it and take the MAGNET out of the magnetron. It’s one of the most powerful ones you can get….and is useful for holding notes and such to the beer-refrigerator in the shop.
(I once found a roasted wasp in a magnetron that was blowing the fuse. The cooling FAN in the microwave might also be the culprit…. If the fan quits…the unit will overheat… and blow fuses.
CAUTION: Do not work on an opened-microwave. The radiation from the unshielded magnetron can permanently BLIND you. It really Will Cook-your-eyeballs and other “participles and leticibles” (shades of Brother Dave Gardner for those with long memories.)
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,920
2,328
Western MT
I don't know if it's worth working on although cleaning it with compressed air might be worth a try based on the @GeoHorn post.
bucktail
Jun 13, 2016
1,293
217
MN
Thinking I'll scrap it. It's a 2010 MC appliance model. Only reason I want to keep it is that it will need new braketry. It's a shame that there isn't an industry standard for over the stove mount microwaves.
John T, your thumbnail cracks me up in the context of an electrical thread.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,791
2,350
WestTn/NoMs
I replaced my '96 Frigidaire with a new GE last year. Although the bracket looked completely different, the GE worked with the old one. Good luck.
Spam Bot
Windows Computer
Aug 3, 2024
179
129
Austin, Minnesota/Key West FL
When you buy your new one, open the box and check it for damage. They are very fragile, and if they are dropped, they can damage the case, but there will be no damage to the box. I just had this happen to me last week. They delivered the appliances for the new house, and when they cut the bottom of the microwave box and lifted the top, one corner of it was crushed. Today, microwaves can do most of what an oven can.
