M7060 - 3-Point Hitch control lever at the rear of tractor.
SDT
multiple and various
Apr 15, 2018
3,323
1,103
SE, IN
On several videos that are on the 'net I've noticed a 3-point hitch control lever that is located at the back of the M7060 tractor which makes it easier to connect an implement (see photo below). Does anyone know where one of these can be purchased?
By-the-way, the videos I'm referring to are from European countries so maybe this option is unique for them.
There is a positioning control on the rear fender of the M4 but not on the 7060 unless it has been recently added.
The control on the M4 is a bit of a Rube Goldberg but is helpful in certain circumstances.
SDT
Apr 15, 2018
3,323
1,103
SE, IN
Actually most companies offer it particularly on cabbed tractors larger than CUT. They usually have an electric switch located on the rear of the fender or 2 buttons to move the hitch up or down at an extremely slow speed. They have been offered since the late 1980's. Very helpful when trying to get pins aligned when you don't have a quick hitch.
Bingo.
Never seen any such controls on smaller tractors sold in the US aside from the mechanical version on the M4.
troverman
Jun 9, 2015
1,178
264
NH
Bingo.
John Deere 4066R is a compact tractor with both external hitch controls and the ability to creep forward or backward:
edritchey
Jul 19, 2014
1,124
831
Wellsville, PA
I added that ability to a MX5400 I used to have the Workmaster 75 I have came with it. In my opinion they should all have it especially in cab model tractors.
g_man
Feb 3, 2023
301
1,354
NE Vermont
On my M5640 I made a lever that clamps onto the 3ph control lever at the operator station and extends out the back so that I can raise and lower the 3ph from the back. The linkage is all mechanical, When I am standing on the ground where I can reach the OEM lever I can't see the 3ph over the rear fender this rear lever made things way more convenient. Kind of crude but simple and works very good.
5,771
I added that ability to a MX5400 I used to have the Workmaster 75 I have came with it. In my opinion they should all have it especially in cab model tractors. View attachment 159899
When I was killing time at a local Kioti dealer that was a feature on several models I looked over.
Seems like something a clever owner could easily add with an inexpensive remote control cable
edritchey
Jul 19, 2014
1,124
831
Wellsville, PA
I added that feature on my MX5400 Cab tractor it is something that really should be a standard feature on Cab Tractors in my opinion I also added the ability to control my hydraulic top link from the same location between those two additions it made hooking up anything to the 3 point a lot easier.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
268
161
NH
I had fabricated a rod that attached to the linkage that the cab lever cable attaches to on top of the transmission. Has a handle on the other end of the rod that I could push or pull from the back of the tractor to control the lower links. Simple and worked perfectly.
Unfortunately, I installed a couple of rear remotes on the tractor that changed the linkage so my fix wouldn't work anymore. Got to come up with a new design.
