M6800 starter issues
ufcxl
Dallas, TX
Howdy. Have a M6800 that won't start. Pulled the starter. Didn't spin freely so have it rebuilt with new solenoid. Still nothing. Hear a faint hum when turning key to start. Starter Relay? Insn't that behind the instrument panel? I think I'd have to pull the steering wheel?
Any thoughts before I tear into that?
DrankTheOrangeKoolaid
M6800/M920, Case 780B
Sep 24, 2019
99
34
Alberta
Starter relay is behind the instrument panel and you will need to pull the steering wheel. But first, two words :)... voltage drop test.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,241
157
Coyote Flats,Texas
I suggest to clean/tighten all 4 battery cable connections. Then check battery voltage while attempting to start engine as other member suggested.
2,931
1,044
Are you having the starter completely rebuilt? Or just putting a new solenoid on it?
