M6800 starter issues
ufcxl
Dallas, TX
Howdy. Have a M6800 that won't start. Pulled the starter. Didn't spin freely so have it rebuilt with new solenoid. Still nothing. Hear a faint hum when turning key to start. Starter Relay? Insn't that behind the instrument panel? I think I'd have to pull the steering wheel?
Any thoughts before I tear into that?
DrankTheOrangeKoolaid
M6800/M920, Case 780B
Sep 24, 2019
99
34
Alberta
Starter relay is behind the instrument panel and you will need to pull the steering wheel. But first, two words :)... voltage drop test.
Tx Jim
M7040 HDC-1,JD 4255,Ford 6700
Apr 30, 2013
1,199
128
Coyote Flats,Texas
I suggest to clean/tighten all 4 battery cable connections. Then check battery voltage while attempting to start engine as other member suggested.
BAP
Dec 31, 2012
2,759
873
Are you having the starter completely rebuilt? Or just putting a new solenoid on it?
