My m5700 won't shut off. I replaced the ignition switch but it didn't work. Anyone have any ideas?
Thanks
Dustin
Thanks
Dustin
I checked the solenoid by bypassing the wiring and it works. It is not getting any juice.Have you checked your fuses yet?
I could be wrong... but it seems to me the shutoff solenoid probably only gets power in the "run" position. If it drew current in the "stop" position it would drain the battery.
Doesn't that have an external solenoid and linkage? Can you shut it off by manually moving the shutoff arm to the stop position? If so, test the operation of the solenoid and see if it is powered in the run position. I'd suspect a sticky linkage or the return spring if the solenoid is working and the fuel pump arm won't return easily/freely to the stop position.
