M135X Transmission wiring
FarmerRae
Kubota M135X Tarctor
Jul 1, 2026
OK
Hi, Is there anyone out there with access to a wiring diagram for the M135X transmission? I guess mice got to it because there are multiple wires broke/chewed apart. It's been fairly easy to splice everything back together, it's just there are 4 plugs right there under the inspection plate that so look the exact same. Each have a red and black wire with a yellow wire. Each yellow wire has a different colored stripe. I need to know which goes where. Thank you in advance for the help. Very much appreciated.
3,109
There should be a wiring diagram in the operating manual if you have one.
Look through this thread or see if there is a manual here
whitetiger
Nov 20, 2011
3,726
2,148
Kansas City, KS
First, we really need the correct and complete model number.
There are serial number breaks, so we need the serial number.
This may be what you need, but again, I do not have the complete model & serial numbers.
Main #1=Y/B
Main #2=Y/W
Main #3=Y/R
Main #4=Y/G
