M135X Transmission wiring
FarmerRae
Kubota M135X Tarctor
Jul 1, 2026
OK
Hi, Is there anyone out there with access to a wiring diagram for the M135X transmission? I guess mice got to it because there are multiple wires broke/chewed apart. It's been fairly easy to splice everything back together, it's just there are 4 plugs right there under the inspection plate that so look the exact same. Each have a red and black wire with a yellow wire. Each yellow wire has a different colored stripe. I need to know which goes where. Thank you in advance for the help. Very much appreciated.
3,003
There should be a wiring diagram in the operating manual if you have one.
Look through this thread or see if there is a manual here
