Loosing power
kcs 61
B2650 , BH77,FDR1660, PFL2042,RCR1860,RB1672, RTR1258,BB1260
Apr 8, 2024
60
27
Va
Ok got an up date. Got my tractor looked at and the mechanic said the main relief valve had low pressure coming through it. He adjust it and working fine now. He said when they get some hours on them they sometimes need adjustment
6,979
How Do you adjust it? and Check it?
You measure the tractor relief pressure setting by connecting a gauge to the pump supply line.
If needed you adjust pressure by adding or removing shims in the relief valve.
READ and UNDERSTAND the procedures in the WSM for the specifics of your tractor. Doing it incorrectly can give you incorrect measurements, cause more problems, and possibly damage expensive parts.
Now, why are you asking?
Joe.G
BX25 W/601
Oct 13, 2024
NY
Dan, I already check and adjusted that following the proper procedure. I was just wondering if they were adjusting something else.
