If you don't need your mid PTO for a mower or something else the subframe can stay on all the time.Does the frame stay on all the time? Did you use existing hole in the frame or did you have to drill new holes.
This is exactly the type of setup I am looking for. Being able to leave the loader frame on and use the front mount snow blower.
I remove it during summer because I have a mid mount mower. It's really easy to remove and install and even if I wouldn't use the mid PTO, I would still remove it in summer because it lower the clearance under the front axle.
No i didn't drill any holes, the subframe is using the existing holes in the frame.
