I suggest you investigate TWO NEW aftermarket cylinders. Probably the most reliable and least expensive repair.Looking for the head (I think it is part number 75540-64310) for my LA481 cylinder OR a used cylinder. Threads on mine are stripped. Thanks and God Bless.
The OEM cylinders are basically generic cylinders. You need to measure them and then match them up.What are the two new aftermarket ones? I've been looking and, being new to searching I couldn't find any. Thanks for your tip and God Bless.
This is very close but 2" bore. Should work and give you about 24% more breakout force. Check the dimensioned drawing to make sure it will fit the mounting ears on your loaderOEM bore 1.75 inches
stroke length 17.625 inches
retracted length 26.000 inches
size of pins 1.000 inch in diameter
