Loader LA481 right tilt (bucket) cylinder
egghead
Kubota LA481 loader
Sep 27, 2026
FL
Looking for the head (I think it is part number 75540-64310) for my LA481 cylinder OR a used cylinder. Threads on mine are stripped. Thanks and God Bless.
7,363
I suggest you investigate TWO NEW aftermarket cylinders. Probably the most reliable and least expensive repair.
egghead
Kubota LA481 loader
Sep 27, 2026
FL
What are the two new aftermarket ones? I've been looking and, being new to searching I couldn't find any. Thanks for your tip and God Bless.
7,363
The OEM cylinders are basically generic cylinders. You need to measure them and then match them up.
You need to know the OEM bore, stroke, retracted length, and size of the pins.
egghead
Kubota LA481 loader
Sep 27, 2026
FL
OEM bore 1.75 inches
stroke length 17.625 inches
retracted length 26.000 inches
size of pins 1.000 inch in diameter
7,363
This is very close but 2" bore. Should work and give you about 24% more breakout force. Check the dimensioned drawing to make sure it will fit the mounting ears on your loader
