Leaky Sprayer Tank
LarryBud
L3130
Dec 5, 2020
249
129
Cleveland, MO
I have a 40 gallon Finco 3 point Sprayer which serves my needs just fine. Unfortunately, the tank has a small leak around one of the bolts which holds the tank to the support frame. When full, I have a constant dribble. Last year during spay season, my every move could be tracked as you followed the trail of dead grass/pasture/ whatever.
I've tried slathering silicone caulk, I've tried this liquid nails guey tape product but no luck to date. I'm thinking I could remove the tank and look at the rubber washers but was hoping for an easier fix. Everything else on the sprayer works great. It's $500+ to replace so I'm looking for a solution.
Any bright ideas Im over looking?
Thanks,
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
A plastic welder would probably be the best bet.
I have the same sprayer, and based on reviews that was common for them to crack around the bolt holes in the bottom. I left them out when I assembled it, the straps hold the tank to the frame just fine.
5,257
1,042
My son has a plastic welder which I used on an ATV fender.
I found that while the welder fused the plastic together, right beside the weld it broke again.
It was like the plastic had lost all its plasticizers. and was brittle
pjoh784350
BX23, quick attach bucket, 3 point, pallet forks
May 3, 2019
168
76
Danville
There is a product called pig putty which is a 2 part epoxy. I've used it in all sorts of places (a stick that is over 20 years old). It's a 2 part and available at Lowes and on line. Amazing stuff. Fixed an actively leaking oil pan in a car while on the road and still leaking. Never had to go back to it!
old and tired
L2800 HST; 2005; R4
Patched a back pack sprayer with this stuff. Need to score the pastic (rough it up) I put cuts into the plastic with a knofe - cross hatch pattern.. I did both, inside and the outside of the tank. It was a 3 gallon tank and I could get my arm in there - not sure you'll be able to do that on a 40 gallon tank.
hedgerow
373
344
Malcolm NE
Larry I have good success with using a fiber glass repair kit with the mat and resin. You would have to take the tank off and sand the tank lightly and then use the patch kit. Have repair many plastic water storage and spray tanks that way. It work well. Friend of mine tried the plastic welding on a sprayer tank and it cracked again were it had be warmed up for the welding process.
3,393
Another product which might work well is Marine-Tex… designed to repair holes in boat hulls. Worked good for me.
Elliott in GA
Mar 10, 2021
784
771
North Georgia
Although I like the suggested JB Marine Weld better, JB Water Weld works very well on just about any surface, and you usually find it at every big box or WalMart store. It cures faster, and it would be a good product to have on hand for a quick repair in the future.
LarryBud
L3130
Dec 5, 2020
249
129
Cleveland, MO
Thanks all who replied. I have a few ideas to work through.
I'll give an update on my results.
WhitleyStu
B2601 LA435 FEL 60" MMM 60" Snow Blower FSP500 Spreader 5' Grahl Roller 40 spray
Sep 10, 2020
58
103
Indiana
I have the 40 gallon Fimco sprayer. Fimco is aware of the issue with the bolt inserts in the bottom of the tank cracking. You might call and see if they will replace the tank. I don't use the bolts in the bottom, just use the two hold down straps.
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
245
50
Southern IL
Have successfully welded several plastic items with a Weller soldering gun with a broad flat tip. A zip tie works well as filler material.
