Lawn Roller
eipo
L4060
Dec 1, 2015
693
81
MI
Been wanting to tackle this project for a couple years. Finaly got it done.
18" x 72" piece of HDPE pipe filled with 13.5 bags of 80# quikcrete. Center rod is 1.5" solid bar. Frame is 3" channel.
sent from a field
4,058
That looks great. Very nice job.
How long would it take you to drag it here from MI? You'd do that for a buddy...right??!?!;)
Might be an issue on I-90 behind your tractor...:eek::rolleyes:
I could really, really use something like that.
That's a great job, eipo!
eipo
L4060
Dec 1, 2015
693
81
MI
Thanks guys.... I drug it around the yard for a bit and got some awkward stares.
sent from a field
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
328
89
Ottawa, ontario
You wouldn't happen to have any build pictures? I assume you had it standing up to fill with concrete.
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
Looks good eipo. Nice fab job. That will cover your tire tracks. I like the bearings on the ends of the shaft.
BigG
Sep 14, 2018
1,949
765
West Central,FL
You might think about adding a scraper blade to keep the debris from sticking to the roller. I have one with a steel pipe and without the scraper it will not stay clean very long.
eipo
L4060
Dec 1, 2015
693
81
MI
I thought I did, but no.
Standing on end was my intention until I decided getting it down would be troublesome. It weighs more than my loader is rated for so I didn't want to chance it.
Laying on its side, I cut a hole big enough to get a shovel on and filled it that way. I screwed osb to the ends which also located the center shaft. There's just a small part on one side that I need to address because the roller wasn't level where we filled it. But all in all it went pretty smoothly.
sent from a field
eipo
L4060
Dec 1, 2015
693
81
MI
I so far in the grass it's been working fine. Not sure I'll use it on dirt. But if I do, I'll likely have to fashion a scraper up for it.
sent from a field
