Land plane or box blade with scarifiers for an icy gravel driveway?
6,355
I'm surprised some 'smart alec' hasn't suggested under road electric heating cables,running 24/7.........
OK, I just did..... Actually the apartment I lived in from '67 to '83 had the concrete ramp to underground parking heated...worked quite well. Hate to think what the cost was though. I'd tidy up the outside lots in exchange for free parking.
a Millcreek spreader would do a great job of laying down sand and grit.
A lot of places up here have heated sidewalks, especially up on the mountain.
I'm doing a heated side walk and garage skirt / apron / approach.
It's relatively cheap for me to do it, and for me to run.
Slabs will all be on 2" of foam, wire mess with PEX pipes at 6" spread.
Our water table at the bottom of my hill is about 10 feet deep, will be using an EX this summer to dig a long wide trench and put 2 loops of HDLP pipe in the ground at about 16' up to a pump that will circulate propylene glycol around to the PEX pipe in the slabs.
The circulation pump running at 35f outside temp.
Ground and ground water temp are in the 50's
This kind of a system does not do very well at removing/ melting snow, but it will keep it from being an icy mess without the need of Ice melt.
This is also dual purpose as the ground loop will also serve as cooling for the house / garage / shop if needed over the summer.
Don't think we'll need the cooling as we stayed in the upper 60's indoors last summer even when temps hit the 100's outside.
6,355
6,355
Need one of these
with this blade!
hedgerow
277
241
Malcolm NE
In my area one inch crusher run lime stone is the common drive way material out in the country. I use my toothed bucket on my skid loader when we get ice build up on the driveway. When it gets real bad I get my heavy ROBO grapple out and use the teeth on it with the skid steer. I run one set of chains on it also and that helps. I always have a pile of one inch crusher run rock around to and will put some of it down if needed. Ice build up is no fun to deal with.
1,413
Would a Harley rake do anything on the ice or would it just tear itself up?
nbryan
Jan 3, 2019
1,231
763
Hadashville, Manitoba, Canada
Our parking area covered with packed snow became solid smooth ice late last winter to where walking involved walking bent-kneed with my arms spread out and crab shuffling to cross it in one piece. The slightest slope spelled real danger.
Enough was enough, had to try something, so put the box blade scarifiers down about and inch and shortened the top link to gain a sharper attack angle and let 'er rip!! pun intended.
I crisscrossed 3 directions and ended up with a well roughed up lot that had decent footing traction. At least a rough groove every 6" at most. It also absorbed sunlight better and sped up late winter breakup.
2,742
854
A set of single diamond or double diamond studded chains on your tractor will do wonders for breaking up the smooth ice. Won’t make it disappear but will rough the surface up a lot and give you tremendous traction.
Mountainhill
l2501 (l3800 2013/22), Box Blade, post hole digger, Leon's rear blade
Apr 3, 2017
68
55
Nova Scotia, Canada
I keep a load of 3/4 clear stone, spread with bucket. A pile of sand freezes like concrete.
mcmxi
6,289
NW Montana
mcmxi
6,289
NW Montana
I found some photos of the "ice comb" I made for the BX25D rear blade. The original photo is dated January 5th, 2019. It didn't work that well, possibly because the rear blade wasn't heavy enough.
je1279
Dec 6, 2020
727
468
Upstate NY
I am happy to report that I have found the solution. Three days of 50 degree plus winter temperatures will remove the ice buildup from your driveway.
mcmxi
6,289
NW Montana
I am happy to report that I have found the solution. Three days of 50+ degree temperatures will remove the ice buildup on your driveway.
Nice! I had similar results on the south facing asphalt driveway after three days in the 40s. But the gravel driveway which is north facing is still a luge track!
ridgerunner85
L3200
Dec 19, 2019
19
PA
Someone may have already mentioned this but….wouldn’t some 1a stone be the best alternative on your driveway?
JoeBabbs
L3800, FEL, BH, box blade, front tine bucket, hydraulic front angle blade
Jan 20, 2020
26
Ithaca, NY USA
I have a steep 300' gravel drive, with the house uphill. When it snows, I plow the snow downhill. When it gets icy, I use a box blade with scarifiers to break up the ice, running the tractor uphill. By loosening ice and mixing with gravel, I get good traction for driving. By dragging some gravel uphill in the winter, I'm getting a head start on the annual maintenance a steep gravel drive always needs.
Angle of the box blade and depth of the scarifiers matters.
