LA 525 Loader Control Valve
fmscsm
L3901 HST w LA525 Loader
Dec 24, 2022
Pinconning, MI
Hi,need assistance in replacing the knob on the control rod of the loader valve.
Ordered a new one, assumed that the knob was threaded on but obviously not, does anyone out there have any experience replacing these, I don't want to just start hammering on it to beat the knob off as there isn't an obvious way to keep it back on the new one either.
Thanks
6,209
Thanks
It is a slip fit. Pull/pound it off.
2,575
You may want to try heat on the plastic also.
5,970
you 'might' win by placing adjustable wrench UNDER the knob,tighten (well close...) then whacking the wrench close to the 'rod'. The 'shock' should release the knob from the rod, launch it into low earth orbit, then you'll spend 1/2 hour looking for it...... :rolleyes:
lugbolt
ZG127S-54
Oct 15, 2015
5,506
2,214
Mid, South, USA
drill a 1/16 hole right down the middle and stop when it hits metal. Then take your air blow gun and put air pressure down the hole you just drilled and the air will expand the rubber a little and it'll (usually) slide right off.
same for the lever knobs on the BX and B series control levers.
