Hi I posted on another thread about a not start issue but no luck and needed to get the machine up and running and other mechanic friends could not figure it out so I called Bacon Universal and the mechanic troubleshooted and found the the ECU under the seat Pt#TD350-53004 $1097.00 was bad and needed to change so I approved the repair. At this point labor hours was at 10 hrs @$160.00. Part came in, changed it, machine started. When I received the bill it was $6000.00+ I sh*t my self. They added another ECU Assy Pt#1H518-60300 $2186.00 which they never called me to ok that part and no where on the labor notes I saw anything about changing 2 ECU's just the first one under the seat and at this point the labor was 12.50hrs. When I questioned the bill the service manager said oh the 2 ECU's work together and both needed to be changed. This is the whole reason I try to fix things myself. I am trying to find out if its true that both ecu's need to be changed together? If so they still should have called to ok the additional ECU.
Thanks
Jerry
Thanks
Jerry
