L4200 GST Front Leak
woodinville275
Woodinville, WA
I purchased a used L4200 a few months back and have loved this machine. I have been using is a lot lately and noticed this leak at the front left joint this morning. I'm assuming it's a seal that needs to be replaced and am hoping it's something I can fix myself as I don't want to sink a bunch of money into fixing this as the wife is still grumbling about the original purchase. Any thoughts on what this could be? Also, is this something that a mechanically inclined individual should tackle on his own?
Thanks for any input. Pictures attached.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
Get your WSM and Parts manual, and give it a go. The shop manual will take you through it. As long as you have a decent metric toolbox you should be up to the task! Take a jillion pictures while you disassemble it. I always seem to forget to, and end up wishing I had. The parts manual gives you the breakdown of how things go together.
kc8fbl
2014 L3200 HST FEL, 1949 Minneapolis-Moline R
Aug 23, 2012
222
Gobles, MI
I've heard that you can use 80-90 gear oil in there instead of UDT oil. It may or may not stop the leaking. It's worth a try to nurse it til you have time to fix it. However, if it's leaking badly, the gear lube won't help much.
Bluegill
Jan 11, 2012
1,560
Success Missouri
Yep, changing to 80/90 gear oil might stop the leak & is what I run in mine.
Seal not to difficult to replace, I'd just do it.
Loader work with no, or not enough counter weight on the 3 pt can play hell on the front axle components.
5,222
woodinville275
Woodinville, WA
I got it from the parts breakdown that Messicks emailed me. However, now that you have pointed out the correct part number I see that I was reading the wrong parts list. I was looking at the list above the parts instead of below. Thanks Wolfman.
5,222
No problem, I've picked the wrong #'s myself before. ;)
