L3800 Pulling power
Bluegill
Jan 11, 2012
1,559
Success Missouri
What do you use with your tractor for logging?..Boom pole? Im looking into getting one..My buddy has a 790 JD, Boom pole works slick
I use a short boom pole that I made & hang log tongs off the end. If I can't get close enough I use a chain to pull it out so I can get the tongs on it.
bearbait
Dec 9, 2011
4,248
994
New Glasgow Canada
If you get the R4 tires and you want to run chains you will need wheel spacers in order to have enough clearance. With the ag tires you can widen the rims they come on so no need for spacers. Just something to consider.
bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
Sep 6, 2011
579
32
Ventura Ca
I have a Grand L3830 and it pulls like a mule it'll pull a subsoiler 22" deep and it'll pull a 2 bottom plow in our heavy Adobe without problem .
Woody Martin
2013 L3200 HST, 66" Loader, R-4's, L/P 1672 , L/P Box grader, L/P 1572 Rear Blad
Apr 24, 2014
25
Brazil, Indiana
Another heck yes it'll do it, but get the AGs! I'm quite unhappy with the
R4s, having had AGs in the past..
I have an L3200 with R-4's. R-4's work for most of my applications but I will tell you that if a muddy situation pops up, the tires turn one time in the mud and the tread is full. How far you go then is questionable. If your not in your yard, go for AG. Power/ Go for it.
Backfire1
L3800 HST w/ loader, Land Pride 72 in. FM, 8 Ft Disk, 6 Ft blade, 6 Ft rake,
Dec 13, 2014
Fayetteville
Did the OP ever get a tractor? Just curios as to the outcome.
