Do you happen to have the part number for the Racor fuel filter? Any more pictures on the install?
Does this help? I just took a couple more pics of how the hoses are routed, and the mount.
Sent from my XT1585 using Tapatalk
Thanks I need to learn how to post pictures.
I told you wrong in the last post.Thanks I need to learn how to post pictures.
Here is the way the fork carriers are in the Cam SuperlineI told you wrong in the last post.
This trailer I added the fork carriers. Added D rings and did the spare tire bracket under the deck, however I gave it to my dad, just to do most of it all over again to the trailer the tractor is on now. Sorry, I got it mixed up.
The one I added the stuff to in the pics is a Sure Trak.
The one I have now is a Cam Superline, and it came with the fork carriers.
Do you have a list of fittings you used on yours? This may be my next mod. I can see from the pictures you have some 90's and a cut off valve.Yeah I made the mount.
The filter housing is simply bolted to a piece of angle iron, and the angle iron is bolted to the fuel tank support.
There is two welded on nuts there that were unused from the factory.
The reason I chose this over the OEM filter is, one, the location. It partially blocked the oil filter.
Two, it was susceptible to damage.
Three, the increase in size of the Racor filter allows me to use a filter with a two micron media, without hindering fuel flow over the much smaller OEM filter.
Four, the Racor filter is designed to be a water separator and there is a drain on the bottom if ever it's needed to drain the bowl.
Five, is the OEM filter had the outlet hose run up and around the injection pump in a semi circle.
To me that was stupid, because of the amount of air to bleed after replacing the element.
This hose routing practically gravity bleeds. As long as you fill the filter after replacing it.
Looking at it I can see, two plugs, one ball valve, two nipples, and one 90 degree barb fitting and one 45 degree barb fitting. Does that sound about right? What size barb fittings did you use or what size did you measure the fuel line to be? ThanksI don't have a list sorry.
It's all 1/4 inch fittings.
The valve is just a brass ball valve with the handle twisted sideways, shortened and painted red.
The fuel line is quarter inch and I used quarter inch Barbed fittings. Tomorrow I will take a closer look at it and add up exactly what I used and try to make a list for you. The two plugs that are in the back side of the filter housing come with the Parker Racor kit.Looking at it I can see, two plugs, one ball valve, two nipples, and one 90 degree barb fitting and one 45 degree barb fitting. Does that sound about right? What size barb fittings did you use or what size did you measure the fuel line to be? Thanks
Hey Jason, did you get a chance to add the Racor filter? And if so did it go okay?Yes thank you very much, this will be my next to do.
Finally got to it this weekend. One question though what did you do with the factory vent that was attached to the factory filter housing?Hey Jason, did you get a chance to add the Racor filter? And if so did it go okay?
