You are missing the point - AGAIN, what I am saying is if the aftermarket filter was built to the same specs as the oem Kubota, not have a heavier or lighter case.By this analogy are you saying that a heavier filter is better????
So a Studebaker is better than a Ferrari???
Weight of an item has no real bearing on the quality...Wait I take that back the weight of gold is higher the purer it is.
I never mentioned color... ???
But I will add this on the case construction, if you ever have a filter stick on, and rip the case apart getting it off, you will appreciate the thicker, and stronger case.
The point is this also - people say aftermarket filters are "just the same but cheaper than oem" and if that was the case, why are they built different? Absolutely, black and white they cannot be the same if they are built different.
Why pray tell do none of the aftermarket filters have a magnet when the Kubota oem filter has one (on those Kubota filters so equipped) if they are al the same? WHY has NO one answered or even addressed this point, no instead you guys all want to worry about the filter case thickness..... Common, give me a break, I pointed out the case differences because I figured that was some thing that could be observed without a filter disassembly.....
Again, answer me that one question, why no magnet if they are the equivalent or in other words, the same?
David
