So Wix is close to Fram you're saying? Why not buy a fram? 4 out of 5 filters are Fram.
http://www.champlabs.com/sites/champlabs.com/files/man_up/Brand.pdf
Some people can see the filters coming off of the same exact line and still believe otherwise. To each their own indeed.
Sometimes I really wonder why I try. Maybe I should give up.....
But, wait perhaps this will help, in case you misread the above post I made, NO I never said WIX was close to Fram, I posted WIX was closer to OEM.
If you had read the first part, let alone actually paid attention to how things are manufactured, there can be a difference between oem spec'd filters and other filters coming off the SAME line, but built to different specs.
It is called production runs. Production runs VARY according to the particular spec built that day, that week.
Need another example? Look at different quality tires from the same manufacture, yup you guessed it, they are many times built on the SAME production line, but certainly built to different standards in different production runs.
Heck for that matter look at GM, Dodge or Ford trucks, each comes off of their respective production line, but all vary greatly in the make up of the truck.... why are they not all the same since they come off the same production lines?
You provided a USESLESS for factual internal construction information to a Champion filters.
Nothing pertaining or addressing what I habe pointed out is in that "press release" If as you say, all filters are evidently the same, WHY tell me, at least so far,
NONE of the aftermarket filters built with a
magnet in them, if as you say they all come off the same production line?
Why if you say Fram and WIX are evidently the same, is the case on the WIX approximately THREE times as thick as the Fram? Why again if they are all the same and come off the same assembly line?
Why, as I answered CORRECTLY before, different filters are designed to different specs, EVEN if they come off the same assembly line.
Each to there own indeed, I said in a nice way, I do take offence at your condescending way it was directed at me.
Which is why I rarely post these days, just not worth it, why take my time to post facts, and have them so ignored.
So again, what ever floats your boat, whatever way you personally choose to go, it is your tractor and you money, do what you want, heck it is still a semi free country for the most part.
David
