L3450
Cpcareyct
L3560 Bh92 Backhoe FEL EA grapple
Mar 18, 2018
24
Windham Ct
What is the correct procedure to check the hydraulic fluid in a L3450
Level ground? Machine running at idle? Machine off?
hope to float
L3450
Feb 18, 2018
467
60
Ireland
I look down the fill hole and shake the tractor. If I can just see it, there is enough. Sight glass is useless unless I'm parked on a slope. It can't really be too critical because the level changes all the time, eg. loader all the way up/down.
Bottom line is I don't know but I hope NIW shows up with a definitive answer
edritchey
A bunch of cute little Kubotas
Jul 19, 2014
1,082
760
Wellsville, PA
With the loader bucket down and the backhoe in the travel position you should be able to see it in the sight glass if you can you're good to go. ;)
5,339
Yea on an L3450 just level and not running is fine for checking the level.
Dye in the fluid helps a ton on these sight glass units.
You know the sight glass is at your left heel, above the floor boards right. :D
