L3301 3 point hitch parts
thegeologist
L3301
May 20, 2024
Sonora, CA
I've got an L3301 that I've been trying to get set up for 3 point attachments (it's got a backhoe on it now). Parts ASAP was able to find the lower draft arms, but no luck so far on the lift arms or top link. I've had no luck finding a diagram with the dimensions for those three parts so that I can try to find them elsewhere. Anyone have those dimensions or a link to a reference with those measurements? I had no idea this would be such a difficult quest! Even the dealer I got the tractor from grumbled about having to look up the parts. Any help would be appreciated!
Parts #1, 2, and 6 on the diagram.
MOOTS
MX6000
Jun 27, 2019
1,936
2,236
Canton, Georgia
Then they didn’t give you your 3 point parts. When backhoe was installed, 3 point parts should have been returned to you.
I’d start with your salesman. Then maybe shop manager. Bet they have them collecting dust somewhere.
MOOTS
MX6000
Jun 27, 2019
1,936
2,236
Canton, Georgia
They were provided, but are gone now.
Lift rod
Top link
No measurements, but there are the part numbers. Good luck.
5,070
Lift rod
Top link
Prolly ain't gonna be cheap!
5,070
Not cheap at all. Hopefully someone has dimensions. I don't imagine that each tractor model has its own specialized hitch parts. There have to be cross-fitting parts. At least I hope so!
I suspect that you will find this to be a dealer item only.
Consult a Kubota dealer for complete part numbers and cost.
The dealer "whole goods" system, through their SALES dept. MAY be of some $$ help.
Be prepared $$$$$ !
hodge
Nov 19, 2010
2,905
453
Love, VA
They'll be the same as an L2502 and an L3902, so go to the dealership and measure one of those.
thegeologist
L3301
May 20, 2024
Sonora, CA
With some poking around, it seems like the L3301 is basically the same as the L39 and L45 with the only difference being in the engines/hp. Is anyone familiar enough with these models to confirm that? If they're all basically the same setup, then it seems like this kit will work on the L3301.
Fordtech86
L3200
Aug 7, 2018
4,976
5,917
Pineville,LA
I think this kit does work, but I’m gonna tag @North Idaho Wolfman because I remember measuring the arms on my l3200 (pretty sure they are the same on the 3301) for him to verify on another members post like this. It’s on here somewhere if you want to search it.
edit: link to the thread
jyoutz
Jan 14, 2019
3,029
2,082
Edgewood, New Mexico
I
I know it’s the same as the L2501 and L3901. Those are the same machines with different engines. I’m not familiar with those other models that you cited.
