L295DT loader restore, advice needed, pictures
4,669
4,669
Here's a 3/8 NPT on amazon
Is it possible to drill 3/4'' into the cylinder, get this one in the hole, then weld it shut, and it would be reliable?
If you are dead set on this think more along these lines.
joesmith123
L295DT, BX1500
Mar 18, 2023
553
148
earth
Geometry aside thats brass. Not weldable and not suitable for hydraulic systems.
I don’t know what I would do without y’all’s advice
I ended going to hydraulic shop, and they said the same:
change all the lines and use jic 8 fittings
each hard line is 7-8 feet, with 3 fittings attached to it
where I’m at now: build all new lines out of jic 8, emulate the factory lines and place fittings in same locations
later: get proper hoses and adapt to the joystick and to the factory cylinder inputs of 3/8 npt
joesmith123
L295DT, BX1500
Mar 18, 2023
553
148
earth
Ok yes, I am looking at this fitting
it goes from 3/8 to 1/4 npt
I don’t think that’s the route I’ll be taking
it’s gonna be cheaper and easier to do the jic 8 lines, then get adapters to plug into the 3/8 npt thread on the cylinders
If you can somehow help me gather all the parts and order them all at once, I’ll send you $ electronically
-32 feet of jic 8 line
-Each line has: one straight adapter, one tee, and one 90 adapter, totaling 12 adapters
-tool to bend/flare the lines to make them tight
joesmith123
L295DT, BX1500
Mar 18, 2023
553
148
earth
Also if you can somehow link a proper fitting that will go into the ones I cut off (pictured)
I’m guessing it would be jic 8 threaded on one side, then smooth on the other side where it welded into the cylinder
then I’ll drill them out, and weld in those new fittings
4,669
You missed my point. NPT ports suck so if you are goung.to try and salvage the cylinder get rid of them.
Cut that old munged uo crap off all the way back to the cylinder barrel and grind the OD of the barrel smooth. Use the fitting I linked or something similar as a bung. The male NPT end is just a sacrificial pilot to go in the hole in the cylinder and help get everything lined up .
Weld rather than screw the male NPT stem into the hole in the cylinder. Cut the stem shorter or turn/grind it down as needed. When done you now have a cylinder with femalev SAE-6 ports.
If that geometry is too small for the holes in the cylinder use 3/8" male NPT X female SAE-6
joesmith123
L295DT, BX1500
Mar 18, 2023
553
148
earth
Yes, I will keep reading this post until I understand, I think I get what you’re saying
late last night, almost got the loader on the tractor (pictured)
joesmith123
L295DT, BX1500
Mar 18, 2023
553
148
earth
In the picture, I marked where you are telling to grind. Basically I am grinding the entire welded metal adapter on the cylinder?
Instead of the SAE 6, how about I get something with an output of 1/2 Jic 8 male? I would weld the SAE male threaded side into the cylinder head?
I will have to weld these here. What welding setup do you recommend that I can use to do this task?
joesmith123
L295DT, BX1500
Mar 18, 2023
553
148
earth
Ordered these from hose and fittings.com
Do I need to flare them or are these the ones that are flareless?
What tools do you recommend for cutting the lines and bending the lines?
Last two pictures: I placed the JIC 8 fitting next to the seized on fitting
The plan: drill a hole big enough to fit the threaded end, then weld it shut
How do you recommend that I can do this? What tool do I need?
Thanks in advance
4,669
Thanks in advance
Looks like flareless converta-flare sleeves and nuts.
1,436
You can buy tubing benders like this
You need to be sure it can bend the tube you are using. In the older days they sold spring things to use to bend copper tube but not sure if steel can be done by hand. Search tube bender and see various machines that are available. You may also find a local vendor of tubing that would be able to bend tube to match what you removed. They would want to sell you the tubing and maybe charge you to bend it.
The recommendation on the cylinders is to remove anything that is currently welded to the cylinders for a tube connection and start from scratch (there will be a hole in the cylinder wall. The suggestion is to use a straight fitting with NPT thread that is about the size of the hole in the cylinder wall and cut the length of the NPT side to a length that will not extend through the wall thickness. Put in the hole and then weld it onto the cylinder wall.
The external connection style is up to you but the suggestion was to avoid NPTF since NPTF connections are difficult to make and JIC (female 37 degree cone) hose ends are easier to use to connect the hose to a male JIC 37 degree connection point. There are a lot of female port thread types that seal better and easier than NPTF.
For instance the top and tilt cylinders that I recently purchased have JIC female ports ( which are also called SAE ports). There are straight, and 90 degree swivel fittings that are screwed into the port and seal with a o-ring that have a male JIC cone on the other end of the fitting.
At least that’s what I understand from the suggestion.
joesmith123
L295DT, BX1500
Mar 18, 2023
553
148
earth
Yes I understand,
In the picture, the fitting in my hand, is a jic-8 union, the exact one I want to weld onto that area
I do not have grid power, how can I complete this task? What is the equipment that is required?
What is a basic setup, where one can do basic welding and solve issues like the one I am having, without grid power?
1,436
You can probably rent a welder that is run off of fuel if you intend to weld it yourself.
I would take it to a professional welding shop or hire a welder that has a truck mounted welder that will drive to your property.
Since you are “from earth” I can’t make more specific recommendations.
joesmith123
L295DT, BX1500
Mar 18, 2023
553
148
earth
Here's a video of me working with jic fittings
If I screw on that nut, isn't it supposed to tighten onto the steel tube?
Looking at it closely, I cannot see how it would tighten onto the steel tube
Unless, this is a setup that would need a "flare"
Does anyone know?
This hydraulic setup was purchased from hoseandfittings.com, and I do have the SKU's
Edit: not videoed, I did try to tighten the nut tremendously, thinking it would bend the sleeve, and crunch onto the steel tube, making a seal, it did not work
4,669
Does anyone know?
That appears to be a standard JIC flare nut and sleeve. The tube has to be flared using a 37 degree JIC flaring tool to use those nuts and sleeves.
To create a flareless connection using a JIC body with nuts and sleeves like you are trying to do requires a flareless type JIC nut and sleeve. They were invented by AeroQuip who marketed them as VersilFlare fittings. They are also commonly sold as Convert-a-Flare fittings. Hose and fittings sells them in the same section as standard flare nuts and sleeves. They are reliable and easy to assemble but you need to read and carefully follow the AeroQuip assembly instructions attached below.
joesmith123
L295DT, BX1500
Mar 18, 2023
553
148
earth
yes, I will look for the 37° flaring tool for half inch jic line on Amazon,
you’re the man
Jasonized
L3902, LA526, box scraper, grapple, pallet forks, tree ripper, lane shark 3
May 16, 2023
153
42
California coast
Well… Stay away from brass fittings. The metal is simply not strong enough, they do not have reasonable pressure limits.
You could bore out the old fittings with a larger size, tap, then put in a reducing fitting.
then go back to standard fittings. Unless you need to repair rusted out metal around the hole, that wouldn’t need welding.
As for welding…. I suppose you could rent a rig for off-grid..
4,669
you’re the man
A JIC flsring tool is not low dollar - expect to spend $150 for a decent tool.
This is not like brake lines. You are dealing with heavier wall and larger diameter steel tube. Unless you are planning on doing this in a volume basis VersilFlsre is more cost effective.
joesmith123
L295DT, BX1500
Mar 18, 2023
553
148
earth
In this picture is the exact fitting I will be using, its steel
"Then put in a reducer fitting"
I'm gonna use what you're telling me when I get the chance to work on it again
"rent a rig for off grid"
Yes, but I others have said something about "brazing silver"
Would I be able to do this for this application?
