L295DT Hydraulic Lift Arms Non Functioning
jacksork
'79 L295DT
Apr 30, 2020
Vermont
Problem solved:
PB port on the loader valve did not have the correct powerbeyond adapter. The correct power beyond adapter ( 3/4" NPT Power Beyond Sleeve Prince 660312004). Also the hoses needed to be swapped between the PB port and the valve outlet.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,158
949
Williamstown Ontario Canada
Problem solved:
Glad the matter is resolved.
Thanks for posting the low cost solution. :)
Part cheap, labor to fix............
Dave
JRaf
L245DT
Oct 15, 2019
47
Los Olivos CA
Great that you figured this out.
So I take it that sometime in the past, someone opened the case and removed the lever. I guess they were planning on replacing it and never did.
Nice work.
