When I bolted mine on it lined up with the top and side bolts the same as the V1702.
There is so many different combinations of parts on these engines it's very common for something to throw a glitch in things, don't lose faith, it will work.
Looking at the prints, is the the issue the bolt hole in yellow are too narrow?
Do the bolt holes in blue and the pin line up?
I just double checked my V1702 and I don't know how I missed it, But I too had to widen/slotted the holes to make my plate work, I'm sorry I didn't point that out earlier.
You should be able to have a machine shop do it without an issue, or if you have a drill press you could do it.
I made a paper template of what i needed the holes to be and then transfer that to my plate and slotted the holes with a drill bit and die grinder.
