3 point will only raise when loader bucket is in the curled position, anyone have a clue on what tol do or how to fix this? Thanks in advance, John
Has someone worked on it or was the loader put on recently?3 point will only raise when loader bucket is in the curled position, anyone have a clue on what tol do or how to fix this? Thanks in advance, John
it has 7 hosesHow many lines connect to the loader valve? 6 or 7?
Dave
when i move the block valve control screw to off poshion this should put fluid going to 3 point only correct ,,,then noyhing works 3 point or loader ,, the only way 3 point will work is to turn block valve on &put the 2 --3 point control levers(right side of seat)to the rear of the tractor & curl the bucket up it raises great ,,with good power & streanth,,the valve under the seat appears to work correctly,that controles how fast the 3 point lowers down,, thats about all i know to say !!thanks so much for your helpmy computer skills arnt the greatest so please bear with me ! thanks T P JOHNUse the selector on the hydraulic block that wgator pointed out to isolate the issue.
One direction will send fluid to the loader valve and the three point, the other direction will only send fluid to the three point.
Report back what happens.
