Bought a one owner L2800 HST last year and it's developed a couple of starting issues. First, I have to rock with the foot pedal back and forth to find a "sweet" spot for the engine to turn over. Sometimes it works the first time and then again I give up and move on to something else and try again later. I feel sure there is a safety switch some where in the pedal linkage that needs adjusting or replacing, but couldn't find it. Any ideas? The second issue is when the starter tries to engage, the drive doesn't seem to engage the flywheel gear. Good (new) battery and starting voltage to the starter. Again, it works perfectly sometimes and then again it'll not engage. The gears are not chipped or broken. I've read where others have installed an other starter relay but don't know if that's the right answer. ANY help is appreciated.
First get some resource material such as a Workshop manual (WSM) from Kubotabooks.com for your tractor.
http://kubotabooks.com/AutoIndex/in...s/&AutoIndex=aae12cb565025bee3e356e8676e88bcc
Look for the section on Operator Presence Control. Section 9-M3.
It will give you a better understanding of the various safety systems on your tractor.
When your starter does not work properly, be armed with a short length of approx 14 gauge wire. Bare about 1/2" of each end exposing copper.
Be very careful as this test can get you run over or worse as all safety features are bypassed. The online WSM is from Scotland. It may not be exactly the same as your machine but will be close. Preferably have someone on the tractor with foot on brake.
On your starter solenoid ( the smaller round upper part that the main battery cable connects to, look for a much smaller white wire. To "Jump," the starter first touch one bare end of your test wire to the large battery cable terminal. Next, when you touch the other bare end of your test wire to the terminal with the small white wire, the starter should immediately engage. There may be some small sparking as you touch but no concern.
If the starter does not engage and operate vigorously, then you ave identified your culprit. If it does operate as it should, then your issues lie in the Operator Presence Control circuit.
Section 9-S13 shows a similar test with the starter off the tractor. Clearly a safer way to test if you are uncertain.
Good luck and feel free to ask more questions.
