L2501 tach cable part #
Blondie70
L2501DT('18)L2501('15)
Aug 6, 2016
256
Poplarville, MS
Howdy.
Does anyone have the part # for the tach/hourmeter cable ? I am searching for one online and not having much luck. This part needed for a L2501.
Thank you, Pete
Fordtech86
L3200
Aug 7, 2018
4,914
5,805
Pineville,LA
Please double check me, I did not know which one of your 2501 listed you needed it for. Does not appear the hst is different then gear drive.
Go to electrical (I know it does not seem right since it is a mechanical gauge), then to panel (first panel option) and there is the cable.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
I looked it up in the Kubota parts list which also showed two different part numbers and gave no clue which was which. At least the Messick's page shows one has replaced the other. If the length is the same the same tack cable should work on either type L2501.
