L2501 3PH stabilizer problem
Pawnee
L2501
Jul 1, 2021
379
346
Ontario Canada
I turned the pins around on my rotary cutter but it was really narrow then so I ended up with one pin normal and the other turned around.
That was the best solution.
Other than spacers, which I think will put everything right.
NvRudder
L2501DT, LA525, R14's, Bison NVHA210 84" RB, Allied 60" SB, Diamond C 10k Dump
Jun 15, 2021
88
104
Northern NV
Something doesn't make sense here...
My new L2501 w/R14's measures 30.5" between the tires...
Attaching QH with QH compatible Rear blade and attaching non-QH 60" Allied Snowblower also presents no issues with manual Stabilizer to Tire clearance...
Chanceywd
Mar 26, 2021
873
868
central ny
I have the same tractor and tires as yours NvRudder. I just measured a bit over 30" between. The wheels say titan EW and this #0319939 then 19.5x12.25. Are the OP's wheels the same? Maybe not the same wheels or dealer got them mixed between two tractors?
NvRudder
Jun 15, 2021
88
104
Northern NV
My wheels are exactly the same as yours...
Some kind of mismatch or wheel substitution seems like a potential part of Pawnee's spacing issues???
Orange man
Kubota L2502 LA526 loader , woods prd6000 mower, Land pride RB 1672
Jul 23, 2014
260
169
WNY
I have the same wheels, But what part of the tire are you guys measuring?
Chanceywd
Mar 26, 2021
873
868
central ny
The distance between the tires at sidewall, at the back of the tractor is where it is easiest to do.
Orange man
Jul 23, 2014
260
169
WNY
My tractor measures 31.5 wheel to wheel, at the cheek of tire its 29.750, out closer to tread its 30.5. So that's why I asked what point on the sidewall you are measuring. Air pressure and load on tire is going to change also. So maybe measuring wheel to wheel would be a good place to start.
Chanceywd
Mar 26, 2021
873
868
central ny
Ok I went to measure mine and got the same as you at the wheel rim edge, 31.5. My 30 measurement is at the fattest part if the tire between them.
Pawnee
L2501
Jul 1, 2021
379
346
Ontario Canada
I measured the inside wheel clearance at the wheels. It's 31-1/2". so the same as the others.
I guess the tires I got are a bit wider but they work great so I'm leaving them as-is.
I ordered wheel spacers so when I'm done I will have 35" wheel to wheel and about 32-1/2" between the tires.
That is enough to clear the lift pins on the rotary cutter with 1/2" extra so I will be one happy farmer(wannabee).
Thanks guys!
