L245DT Front Axle - chipped gears
shootem604
Apr 23, 2018
875
British Columbia
I haven't been on here for awhile, but I'm back, with a request for help.
I was using my L245DT a couple days ago and hear a mechanical "bang" sound. Stopped, couldn't figure out what it was. Kept on going. Every 6 feet or so another "bang". Was thinking this sounded expensive, probably gears. My clutch is a little out of adjustment, and shifting has been difficult, so thought transmission. I put the tractor up on jack stands and ran through all the gears, low and high range - could hear/feel a regular thump, but not in 2wd, so figured it was a front axle thing. Spun the front wheels, nothing. Let the tractor spin the wheels in first while I watched (safety police, shh) and noticed a "jump" at the bearing where the drive shaft connect to the front differential. On closer examination, I could see a crack in the flange of the bearing housing. I pulled drive shaft, pivot pin, steering, and dropped the front axle. When I spun the input shaft by hand it would bind up occasionally. I removed the bearing house/input shaft whenever it bound up and noticed the differential side gear had a number of chipped teeth. That's where I am now - I think I've diagnosed the problem, but fixing it is going to stretch my limited skillset. Suggestions on what to do next? Replace the whole front axle? Can I pull everything apart and replace just that gear?
4,030
shootem - look up Lance aka 007kubotaguy here on OTT. He’s helped a lot of folks with older L’s. Send him a private message or email.
4,030
The pinion looks ok. The crown gear is pretty chewed up. It's an obsolete part I can't get anywhere...
shootem - - if you notice 007kubotaguy gave a thumbs up ( 👍 ) on my post about your L245 part.
Sounds like you might have a source....
Best wishes - - hope it works out.
fj40dave
Sep 24, 2009
418
254
Yelm, WA
Lance has been awesome for the couple of 245's I keep running!
shootem604
Apr 23, 2018
875
British Columbia
Thanks to all! Hopefully we can keep this old girl working with some new parts.
shootem604
Apr 23, 2018
875
British Columbia
Thanks to Lance I'm back up and running. Just in time, too, as we had a snowstorm a week after I fixed it.
