L2250 tires help
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
657
268
Herald Calif.
I would have a set of AG wheels for the front. I see you're in Southern California I'm in central california. Send me a message if interested.
Anthony250f
20
San Diego
Different engine on your L2250. Your tractor is the direct predecessor to my L2350.
What’s odd though is online it lists a spin on for my engine
also when I checked it out mine ONLY had the filter and the spacer. In this parts diagram. Don’t know how important the other two missing parts are here circled in red
it also has a pretty good hydraulic leak around the rear axle. Not sure if it’s worth chasing it down.
Flintknapper
L2350DT
May 3, 2022
1,834
2,310
Deep East Texas
No problems with that large of a front tire/wheel??
Its the correct size for the front differential gear ratio which needs to closely match the rear (if in 4WD).
No, no problems. Factory spec for MY tractor .
IF your L2250 is not 4WD...then choose whatever you like.
Anthony250f
20
San Diego
I looked up the specs for your tractor and it says online it should have the same 9.5-24 rear and 6-14 front which is the same mine calls for. So sounds like 11.2-24 rear and 7-16 front should work out for mine too
Flintknapper
L2350DT
May 3, 2022
1,834
2,310
Deep East Texas
For an R1 type tire (rolling circumference) the specs I provided are correct and should work fine on your tractor. Has worked fine on mine for 28 yrs.
It has been discussed before.
WAS BANNED FOR NSFW PICS
5,143
I suggest that you clean the underside of the tractor with a pressure washer to get all that grime off, and that will give you a better idea of what is leaking and how bad the leak is. It will also lessen the chance that your tractor will go up in smoke. I learned early in life that if you have to wrench on something you want it to be clean so you can clearly see what you are doing and you will not be contaminating the inside when you remove a part. Think of yourself as the surgeon and the tractor is your patient that you are operating on. No room for excuses or mistakes.
Anthony250f
20
San Diego
This is after about 30 mins with a pressure washer LOL. Should have seen it before. Zero blue showing. I cleaned it up more and it’s 100% coming from the stud that goes from the transmission to the right side brake case. Unfortunately that means I have to split the cases and reseal.
The oil pan leaks a bit too.
nlewis
1989 Kubota L2250F
Jan 27, 2025
Hattiesburg, MS
After some searching and much help from their customer service, I found these. We double checked all the measurements over the phone and they should work. 2 new wheels painted orange for less than $300 shipped.
Anthony250f
20
San Diego
I bought mine from quality farm supply but they looked identical minus the size
