Hi All -
I checked the workshop manual and I'm still not sure what I need to do here. This is a Kubota L225
When I go to high RPM and a load on the engine, oil is badly leaking out of the area near the cooling inlet behind the generator. I've attached a few pictures.
This got progressively worse as I worked yesterday until I ultimately had to shut it down. I suspect I've lost a gasket somewhere, but I'm not sure which.
Could it be the oil pump gasket? Why would it be squirting out all the way up there?
Very little leaking at low RPMs.
Any ideas?
Thank you!
Any ideas?
Thank you!
