L2201DT tiller stuck up
DaTow'd
what ever it takes to get the job done
Aug 13, 2013
238
224
Bella Coma BC Canada
Hi Gang,
Our trusty L2201 DT's tiller is stuck in the up travel position and will not come down. The operating level feels like nothing hooked to it.
Any Idea what to check before I remove the top cover under the seat
'thanks
Hank
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,188
1,173
E.
It seems like you think it's a lever linkage issue. But before you start investigating maybe a quick and easy check to make sure your 3pt drop speed lever isn't turned off.
does your tractor have a valve with a knob on it under the seat (between your knees).
If it does make sure its not closed tight. (open it / rotate knob)
11,160
This model doesn't have Monromatic three point does it?
Monromatic is electrically controlled three point.
Check the feedback linkage, should be a bar that goes from the three point arms to the valve linkage.
nbryan
Jan 3, 2019
1,432
948
Hadashville, Manitoba, Canada
tractorcharts dot com says its got a position control 3-point.
