L2201DT tiller stuck up
DaTow'd
what ever it takes to get the job done
Aug 13, 2013
241
239
Bella Coma BC Canada
Hi Gang,
Our trusty L2201 DT's tiller is stuck in the up travel position and will not come down. The operating level feels like nothing hooked to it.
Any Idea what to check before I remove the top cover under the seat
'thanks
Hank
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,199
1,187
E.
It seems like you think it's a lever linkage issue. But before you start investigating maybe a quick and easy check to make sure your 3pt drop speed lever isn't turned off.
does your tractor have a valve with a knob on it under the seat (between your knees).
If it does make sure its not closed tight. (open it / rotate knob)
11,232
This model doesn't have Monromatic three point does it?
Monromatic is electrically controlled three point.
Check the feedback linkage, should be a bar that goes from the three point arms to the valve linkage.
nbryan
Jan 3, 2019
1,433
950
Hadashville, Manitoba, Canada
tractorcharts dot com says its got a position control 3-point.
DaTow'd
Aug 13, 2013
241
239
Maple Leaf Farmer you hit it on the head.
I guess my grandson was fiddling with it, twisted the knob and the tiller slowly sank down
thanks
Hank
5,536
There is no better way to test your knowledge of your tractor than having a grandson playing on it :love:
My grandkids turn and twist every knob and lever they can,.......So I have to "troubleshoot" it every time I get on it:ROFLMAO::ROFLMAO::ROFLMAO:
