L185DT Bent Bevel Gear Shaft
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
678
289
Herald Calif.
Great. Looks like my box survived the 3,000 mile ride. You should not need a puller to get the axle gear off. Just remove the snap ring and it should come right off just
TwitchyMcJoe
1980 L185DT
Yeah, it should, except that one of the loose ball bearings or, the other gears, put a few dents in the end of the shaft. Pulling the gear with a puller will reshape it though, and the new one will slide right on.
Thought I should mention that the groove for the snap ring is fine, despite how bad it looks. I pulled the snap ring before this picture.
007kubotaguy
Dec 23, 2012
678
289
Herald Calif.
Yeah, it should, except that one of the loose ball bearings or, the other gears, put a few dents in the end of the shaft. Pulling the gear with a puller will reshape it though, and the new one will slide right on. View attachment 126940
If you need axle just let me know and I will send you one.
TwitchyMcJoe
1980 L185DT
Not needed. It's beat up, but serviceable.
I had to angle grind some slots in the old bevel gear to pull it off with the puller. Cleaned the splines with needle files.
Now to borrow a torque wrench and buy some gear oil. Finally I'll be able to mow again. The field is getting tall.
