Great. Looks like my box survived the 3,000 mile ride. You should not need a puller to get the axle gear off. Just remove the snap ring and it should come right off just
Yeah, it should, except that one of the loose ball bearings or, the other gears, put a few dents in the end of the shaft. Pulling the gear with a puller will reshape it though, and the new one will slide right on.Great. Looks like my box survived the 3,000 mile ride. You should not need a puller to get the axle gear off. Just remove the snap ring and it should come right off just
If you need axle just let me know and I will send you one.Yeah, it should, except that one of the loose ball bearings or, the other gears, put a few dents in the end of the shaft. Pulling the gear with a puller will reshape it though, and the new one will slide right on. View attachment 126940
Thought I should mention that the groove for the snap ring is fine, despite how bad it looks. I pulled the snap ring before this picture.
Not needed. It's beat up, but serviceable.If you need axle just let me know and I will send you one.
You did fill all three places right?She lives.
I found no oil in the other gear case or front differential. I will keep an eye out for leaks, buy no wonder the bearings failed
Yes, I did. Both bevel gear housings and the differential.You did fill all three places right?
