If I replace my head on my l185 can a extrenal temp guage be add
and if so where and what temp should it run. i realize it has a whistle.
Can whistle go bad and can it be tested?
Here is a pic of what I'm doing on my L175 for a temp guage. This is a "temp kit" from Auto Meter and I'm using a "shorty" sender in the front head cover. Pic following too.
This water cooling system was intended for use with "WATER" only and cannot benefit from antifreeze!!!!!
A chemical "wetter" can be used in the water to dissipate heat much faster but antifreeze RAISES the boiling point which also slows the circulation of water. As the temp raises the head is getting pretty hot since the exhaust is also run through the coolant jacket to speed circulation.
With water only the tractor will run very stable at 212° since that is the boiling point of water. The water will be circulating as fast as you see water moving in a pan of boiling water.
The stupid screamer will not work with anything other than water!!!!!!!!!!! It is basically useless to me. If enough steam could be made for it to work with antifreeze then of course the engine has already gotten damaged, which is what happens with most failures.
I don't know exactly what temps it would run at with antifreeze but since it boils in the range of 230° it is possible that 240° could be reached with slow circulation. This is pure speculation from a trained person. I am going to log temps on my engine when it is running to find out what is going on.
Wetter made by Redline can also be used with WATER and it is supposed to dissepate heate 30% better. I have som wetter that I am also going to try and log the temps.
What I expect to do on my tractor is use an electric inline circulation pump, at the lower radiator hose and control it with a relay on a temp switch. This way the pump would run to cool and shut off to warm up.
