oldtown
L175, 1977 model . caroni finish mower , first choice tiller 6 scrape blade
Ok so we decided not to sell the tractor. the 1977 model does need some attention.
first the tractor wont start without jumping off my truck. battery is new not sure if it is the right size what size do i need ?
the front tires are falling apart and i would like to replace with a different tread, the size is 4.00-12
howdo i test the alternator to see if it is charging. ?
there also seems to be an oil leak arouund the base of the steering column. it was very cold when i noticed this?
the tractor has given great service over 10 years and now it is time for me to give back.
i want to also check injectors, glow plugs as well as adjust valves.
thanks in advance.
thanks in advance.
