L 3650
Pau7220
Aug 1, 2017
785
277
Scranton, PA
It’s where your left foot hits the trans hump.
jgum
L 3650 kubota
Apr 17, 2022
60
West virginia
Yesir i pulled the chassie cover off and there’s no sight glass just has me stumped i figured maybe a over fill bolt hole that would work as an over flow so u know when it’s full
5,476
You don't have to pull any cover to see it, it's right on the side of the cover.
Are you sure you have a L3650 and not a 3560? or some other variation of numbers?
I looked at all the Various Models of L3650 and all for models have the sight glass.
Take a picture of the side of the Clutch Housing behind the clutch pedal, because I wonder if someone has put a plug in the hole? or something else odd?
Pau7220
Aug 1, 2017
785
277
Scranton, PA
Click the link below. And the pic in post #6.
FYI, there have been cases of some glasses being painted over.
jgum
L 3650 kubota
Apr 17, 2022
60
West virginia
I’ll agree with you on they prolly put a plug in the hole cause i pulled the cover off the classy cleaned everything off with some brake clean and no sit glass to be found when i get back home in a few weeks from work I’d be happy to send some pics to u
jgum
L 3650 kubota
Apr 17, 2022
60
West virginia
And yes it’s an L 3650
5,476
It's a half circle cut out at the bottom of the cover just above the step.
I've seen them packed with dirt where you can't see it.
5,476
That is really odd!
Look under the seat or behind the seat or on the back cover above the PTO.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,462
1,272
WestTn/NoMs
Here's what the OP Man shows, but I can't tell where it is. Is it behind that gap next to the clutch pedal? What's behind that slot on the right side of the tunnel?
jgum
L 3650 kubota
Apr 17, 2022
60
West virginia
On the right side there’s nothing just some letters and numbers the wife is going to do some more photographer work for me I’m in New York and she’s in West Virginia at home
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,462
1,272
WestTn/NoMs
There is what looks to be a rectangular slot in the fourth picture on post #14. Maybe look through there?
