Yesir i pulled the chassie cover off and there’s no sight glass just has me stumped i figured maybe a over fill bolt hole that would work as an over flow so u know when it’s fullIt’s where your left foot hits the trans hump.
You don't have to pull any cover to see it, it's right on the side of the cover.Yesir i pulled the chassie cover off and there’s no sight glass just has me stumped i figured maybe a over fill bolt hole that would work as an over flow so u know when it’s full
I’ll agree with you on they prolly put a plug in the hole cause i pulled the cover off the classy cleaned everything off with some brake clean and no sit glass to be found when i get back home in a few weeks from work I’d be happy to send some pics to uYou don't have to pull any cover to see it, it's right on the side of the cover.
Are you sure you have a L3650 and not a 3560? or some other variation of numbers?
I looked at all the Various Models of L3650 and all for models have the sight glass.
Take a picture of the side of the Clutch Housing behind the clutch pedal, because I wonder if someone has put a plug in the hole? or something else odd?
And yes it’s an L 3650I’ll agree with you on they prolly put a plug in the hole cause i pulled the cover off the classy cleaned everything off with some brake clean and no sit glass to be found when i get back home in a few weeks from work I’d be happy to send some pics to u
Which one?And yes it’s an L 3650
Pretty sure it’s an L 3650DTWhich one?
L3650 F
L3650 DT
L3650 WET
L3650 GST
Ok, they really are all in about the same place.Pretty sure it’s an L 3650DT
From what everyone is saying you can see the sight glas But on this tractor you can’t even see the chassie it has a cover over itOk, they really are all in about the same place.
It's a half circle cut out at the bottom of the cover just above the step.
I've seen them packed with dirt where you can't see it.
Do u think there is a dipstick. It has me baffledThat is really odd!
Look under the seat or behind the seat or on the back cover above the PTO.
There is what looks to be a rectangular slot in the fourth picture on post #14. Maybe look through there?On the right side there’s nothing just some letters and numbers the wife is going to do some more photographer work for me I’m in New York and she’s in West Virginia at home
