Kubota ST30 adapting a front loader & fitting problems
KuboST30
KUBOTA ST30
Sep 6, 2026
Uttoxeter UK
Hi. I am fitting a newer LA545 loader to my ST30 and have changed/adapted the loader post to fit the ST30 base plate. I Drilled the subframe today carefully to avoid any internal pipes a d as soon as my pilot drill went through the subframe red oil is pouring out???
There isn't any pipes near or going into the frame there so is the subframe full of hydraulic oil or did I think a hidden pipe? Any help as there shouldnt be any pipe here that i can see from checking on the outside- they are further downstream as you can see in the photo! Any ideas or info about hidden pipes on a ST30 subframe?
11,176
You going to need to add a picture of where you drilled as we don't have ST30's in the US.
Whatever you tried to attach didn't get attached. Use the icon with the Square with a mountain and a sun in it to attach a picture.
Is the subframe on the loader are solid pieces of steel, so no oil there.
KuboST30
KUBOTA ST30
Sep 6, 2026
Uttoxeter UK
Hi & thanks for your reply. Have added the image again you can see a bolt in the hole for now!
It's the subframe on the Kubota tractor rather than the image you have of the loader stabiliser bars
11,176
Ummm that's a hydraulic reservoir that you've drilled into.
You're going to need to have the hole repaired.
Suction or return line in red.
KuboST30
KUBOTA ST30
Sep 6, 2026
Uttoxeter UK
So is the subframe itself the reservoir? I was assuming i had missed any pipes as I was upstream of the pipe that you arrowed in red?
I wanted to put a bolt through this box section- if its actually a reservoir then I could theoretically still drill my bolt hole and then put sealing rings at both ends when I bolt it up? Maybe?
3,578
Can't view photo. Get this:
You do not have permission to view this page or perform this action.
whitetiger
Nov 20, 2011
3,752
2,164
Kansas City, KS
The fact that there is a hose coming out of the frame to the left of where you are drilling might be a clue.
11,176
So is the su frame itself the reservoir? I was assuming i had missed any pipes as I was upstream of the pipe that you narrowed in red?
I wa ated to put a bottle through this box section- if its actually a reservoir then I could theoretically still drill my bot hole and then put sealing rings at both ends when I bolt it up? Maybe?
Yes the frame is a resesivor.
You're never going to keep it sealed up bolting something to it.
My sugestion would be to have a plate made that bolts to the bracket below where you drilled the hole in the tank.
5,497
I am unsure of how thick the metal is, however;
My first attempt at repairing this would be to run the appropriate sized tap into that hole, then get a bolt with some sort of "sealing washer" under the head.
Then, delete this post, and call it a "customized inspection hole", and brag about it..... ;)
Chanceywd
Mar 26, 2021
873
868
central ny
Good idea, like an oil drain plug.
