Hi. I am fitting a newer LA545 loader to my ST30 and have changed/adapted the loader post to fit the ST30 base plate. I Drilled the subframe today carefully to avoid any internal pipes a d as soon as my pilot drill went through the subframe red oil is pouring out???
There isn't any pipes near or going into the frame there so is the subframe full of hydraulic oil or did I think a hidden pipe? Any help as there shouldnt be any pipe here that i can see from checking on the outside- they are further downstream as you can see in the photo! Any ideas or info about hidden pipes on a ST30 subframe?
