So here is a update.
I removed two out of three shims from the injection pump as I suspected I used the shims from the older motor. The engine now starts perfectly with little to no smoke, and runs great until 2400rpms. It does not make the 2600rpms needed for PTO.
I double checked valve lash, which is fine and ran a compression test (521, 522, 520psi) so that is great.
At this point there are only two options left, as its clearly a fuelling issue.
It is either governor injection pump max rpm stop (Kind of odd it produces white smoke)
Or the currently used fuel camshaft can not produce power past 2400rpm, and I will need to take the tractor apart again to replace the fuel camshaft with the original one from the original motor. (I doubt this is the case, but who knows what kind of black magic Kubota has to pull to meet emissions standards on Generators and air compressors.
