B Brewsta New member Jun 20, 2022 2 0 1 Usa Jun 20, 2022 #1 Hi everybody first post here. Anyone know where I attach this purple fuse wire? Bought this mower used. Thank you! Mower dies, needs to be jumped, seems this may be the issue.
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 11,005 2,863 113 Bedford - VA Jun 20, 2022 #2 Brew, welcome to the furom you sure that is not "red" and faded? it is running to that fuse, yes? Reactions: 1 user
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 11,005 2,863 113 Bedford - VA Jun 20, 2022 #3 Have you traced the other end to see where it leads? no pun intended Reactions: 1 user
J jkrubi12 Well-known member Equipment B2601/LA435/QA54"/BH70/B8160box/BB1254/PFL1242/SGC0554/BX2812APlow/WC-68 Chipper Sep 24, 2012 403 299 63 right coast Jun 20, 2022 #4 Looks like a power supply lead imo. Reactions: 1 user
whitetiger Moderator Staff member Equipment Kubota tech..BX2370, RCK60, B7100HST, RTV900 w plow, Ford 1100 FWA Nov 20, 2011 3,249 1,675 113 Kansas City, KS Jun 20, 2022 #5 That wire should be connected to the battery cable post on your starter. That is the wire that connects the rectifier/regulator to the battery. Attachments Z723,Z724,Z725KOHLER ENGINE(SUPPLEMENT) (engusa)-9Y111-10422.pdf 366 KB Views: 145 Reactions: 1 user
B Brewsta New member Jun 20, 2022 2 0 1 Usa Jun 21, 2022 #6 Now it won't even crank over when being jumped.
L lugbolt Well-known member Equipment ZG127S-54 Oct 15, 2015 5,501 2,208 113 Mid, South, USA Jun 21, 2022 #7 starter solenoid. It goes on with the wire that comes from the battery. Reactions: 1 user
