Is this a water well?
Virtual Guy
Kubota L2501, loader, Land Pride box blade and grapple, John Deere MX5 cutter
Jul 17, 2022
86
71
Osage County Oklahoma
I bought property next to our house lot and found this. Looks like it might be a well but it's close to the water meter for our property so maybe it's something related
to that.
2,075
Valve to turn the water off?
Shine a light down the pipe and see what is at the bottom.
WAS BANNED FOR NSFW PICS
5,152
If you have city water, it is probably a shut-off access pipe. I have never seen a white PVC pipe used for a well.
Virtual Guy
Jul 17, 2022
86
71
Yeah it's 4" (I think) PVC. I looked down as far as I could using my phone light. Couldn't see the bottom. I have rural water next door and my meter and valve are in a rectangular box. That's probably what this is, just odd that it's so different. I'll take a flashlight down there tomorrow.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,119
3,381
PVC well casing is pretty common these days in newer installations. It is still 6" though.
There is the possibility that, at one time, it was a manual well pump. Like the old school 4 foot handle pump you see in movies. That could be a smaller diameter.
4,896
Don’t know where you’d find a submersible pump that would fit down a 4” casing.
If you don’t see a valve at the bottom, could be a clean out for a drain line. That wouldn’t be unusual for a 4” PVC pipe sticking out of the ground with a cap that isn’t glued on, at least it isn’t uncommon here. A drain line from what to where… 🤷‍♂️
KKBL
L2501 HST QA 525 loader, 42" forks, brush hog, grader/box/back blades
Jan 5, 2022
125
137
Girard, PA
It appears to be a "curb box". Ask your water provider to verify what property it is for. It may be the curb stop valve for your residence.
Tropical Jack
Kubota L3301 w/ FEL & BH, tilt and trim, chipper, box blade, grading blade
I live in Western NC now. All of the wells casings are 6” PVC. When I lived in FL, all the casings were 4” PVC. The difference is in water levels. Much higher water table in southern FL. 4” wells are common there. Also common to have city water, and a well for irrigation.
Jack
4,071
I am assuming the cap is brass or copper, so I would conclude there is a water shut off at the bottom. Sometimes they are pretty deep the one at Moms house is about 8 feet down due to the way the line was laid
Yooper
3901 LA525
May 31, 2015
1,644
787
NE Wisconsin
Could be a clean out access. I have 3 of them because my sewer pipe run is so long (450’). Code says you have to have them every so many feet if your run is over ??? feet.
6,896
I noticed the cap has a “W” on it. Maybe it’s an M….
Curb boxes around here are much different, but certainly plausible
torch
Jun 10, 2016
2,748
971
Muskoka, Ont.
Drop a plumb bob (or nut on a string, whatever) in there and see how deep it is and how far up the string is wet. Does it clang like it hit a metal valve at the bottom?
5,699
My 'vote' is for the City water feed shut off tap, or whatever you call it...
Clues I see are
1 BLUE paint on the cap, usually blue is for water
2 'W' on the cap, 'M' has straight strokes, 'W' has tilts
3 Band of BLUE paint on the white PVC pipe near ground
Tape a flashlight (NOT your smartfone...) to a rope and lower it down. When you hit something, raise it up a foot then look down. Probably see some 'weird' looking thing,which will be the shutoff valve body.
You 'could' use your phone,set to record, lower it down,just don't blame me if YOUR knot release the phone down there..!
I'd think it might be 6-10' below grade ?
6,642
Clues I see are
I think you're right on! The traces of blue paint and the "W" are the big clues.
